So I was making this code in a script in c# It went just fine, about 339ms.
When I wrote it in my plugin speed went down quite a bit, it became 2500ms
I’m I wondering what’s causing that much delay ? I thought it should work faster.
Here is the script in GH
GHScript.gh (162.7 KB)
Here is the same code in VS
using System;
using System.Collections.Generic;
using Grasshopper;
using Grasshopper.Kernel;
using Grasshopper.Kernel.Data;
using Grasshopper.Kernel.Types;
using Rhino.Geometry;namespace SurfaceTrails2.Composite
public class _28_11_18_Composite_3D_01 : GH_Component
/// Initializes a new instance of the _1_11_18_Composite_3D_01 class.
public _28_11_18_Composite_3D_01()
: base(“Composit 3D”, “Composite3D”,
“Creates YFA composite lines with respect to it’s thickness and 3d Boundary”,
“YFAtools”, “Composite”)
}/// <summary> /// Registers all the input parameters for this component. /// </summary> protected override void RegisterInputParams(GH_InputParamManager pManager) { pManager.AddMeshParameter("mesh", "m", "Mesh to make the YFA composite system on", GH_ParamAccess.list); pManager[0].DataMapping = GH_DataMapping.Flatten; pManager.AddNumberParameter("Naked edge length", "length", "Length of edge on the naked sides of the brep", GH_ParamAccess.item, 0.05); pManager.AddNumberParameter("Clothed edge width", "width", "width of edge on the clothed sides of the brep", GH_ParamAccess.item, 0.01); } /// <summary> /// Registers all the output parameters for this component. /// </summary> protected override void RegisterOutputParams(GH_OutputParamManager pManager) { pManager.AddPointParameter("Composite points", "pt", "pt", GH_ParamAccess.tree); pManager.HideParameter(0); pManager.AddCurveParameter("crv", "Composite curve", "crv", GH_ParamAccess.tree); } /// <summary> /// This is the method that actually does the work. /// </summary> /// <param name="DA">The DA object is used to retrieve from inputs and store in outputs.</param> protected override void SolveInstance(IGH_DataAccess DA) { var meshes = new List<Mesh>(); double nakedLength = 0.05; double clothedWidth = 0.01; if (!DA.GetDataList(0, meshes)) return; if (!DA.GetData(1, ref nakedLength)) return; if (!DA.GetData(2, ref clothedWidth)) return; var edgeTopology = new List<GH_Integer>(); var allEdges = new List<GH_Curve>(); var pts = new GH_Structure<GH_Point>(); var joinedEdgesTree = new GH_Structure<GH_Curve>(); int b = 0; foreach (var mesh in meshes) { for (int i = 0; i < mesh.TopologyEdges.Count; i++) { edgeTopology.Add(new GH_Integer(mesh.TopologyEdges.GetConnectedFaces(i).Length)); allEdges.Add(new GH_Curve(mesh.TopologyEdges.EdgeLine(i).ToNurbsCurve())); } var allEdgesTree = ListOperations.ReOrganize(ListOperations.PartitionToTree(allEdges, 3)); var edgeTopologyTree = ListOperations.ReOrganize(ListOperations.PartitionToTree(edgeTopology, 3)); for (int i = 0; i < allEdgesTree.PathCount; i++) { for (int j = 0; j < allEdgesTree.get_Branch(i).Count; j++) { var GHNurbs =(GH_Curve)allEdgesTree.get_Branch(i)[j]; var nurbs = GHNurbs.Value/*.ToNurbsCurve()*/; var GHInteger = (GH_Integer) edgeTopologyTree.get_Branch(i)[j]; Point3d pt1; Point3d pt2; if (GHInteger.Value != 1) { pt1 = nurbs.PointAtLength(nurbs.GetLength() * 0.5 + clothedWidth * 0.5); pt2 = nurbs.PointAtLength(nurbs.GetLength() * 0.5 - clothedWidth * 0.5); pts.Append(new GH_Point(pt1), new GH_Path(b,i)); pts.Append(new GH_Point(pt2), new GH_Path(b,i)); } else { pt1 = nurbs.PointAtLength(nurbs.GetLength() * 0.5 + nakedLength * 0.5); pt2 = nurbs.PointAtLength(nurbs.GetLength() * 0.5 - nakedLength * 0.5); pts.Append(new GH_Point(pt1), new GH_Path(b, i)); pts.Append(new GH_Point(pt2), new GH_Path(b, i)); } } } allEdges.Clear(); edgeTopology.Clear(); for (int i = 0; i < allEdgesTree.PathCount; i++) { var GHCurveList= allEdgesTree.get_Branch(i); var curveList = new List<Curve>(); foreach (GH_Curve ghCurve in GHCurveList) { curveList.Add(ghCurve.Value); } joinedEdgesTree.Append(new GH_Curve(Curve.JoinCurves(curveList)[0]), new GH_Path(b, i)); } for (int i = 0; i < joinedEdgesTree.PathCount; i++) { for (int j = 0; j < joinedEdgesTree.get_Branch(i).Count; j++) { var GHCurveList = joinedEdgesTree.get_Branch(i); var curveList = new List<Curve>(); foreach (GH_Curve ghCurve in GHCurveList) { curveList.Add(ghCurve.Value); } var GHptList = pts.get_Branch(i); var ptList = new List<Point3d>(); foreach (GH_Point ghPt in GHptList) { ptList.Add(ghPt.Value); } var sortedPoints = PointOperations.SortAlongCurve(curveList[0], ptList); joinedEdgesTree.get_Branch(i)[j] =new GH_Curve(CurveOperations.ClosedPolylineFromPoints(sortedPoints)); ; } } b++; } var x = pts; var y = joinedEdgesTree; DA.SetDataTree(0, x); DA.SetDataTree(1, y); } /// <summary> /// Provides an Icon for the component. /// </summary> protected override System.Drawing.Bitmap Icon { get { //You can add image files to your project resources and access them like this: // return Resources.IconForThisComponent; return null; } } /// <summary> /// Gets the unique ID for this component. Do not change this ID after release. /// </summary> public override Guid ComponentGuid { get { return new Guid("f55238f7-25c9-4468-92c3-7d78622584de"); } } }
PS: all methods shown in the VS code unknown are already defined with the same name in the GH script.
