Hi guys,
I’m working on a CNC model and need to integrate roads into the single polysurface (topo). What’s the easiest way to project and extrude them on the topo?
Thanks for your time!
Sincerely
Deniz
CNC Model.3dm (1.8 MB)
Hi guys,
Sincerely
Deniz
one way:
this should give you a model with the terrain cut into blocks by roads.
also,i see something that looks like a highway overpass. it would be easiest to build the bridge, abutments, and piers as separate pieces that are attached to the topography afterwards. the retaining walls can sometimes be milled out of the same stock as the topography if you have a tapered bit or a 1/16" ball-end bit. alternatively build the retaining walls as separate pieces and attach them to the topography.
make sure the all the curves that you extrude are closed curves
