Hello All,
I have some points inside the Hexagon and got the middle points of Hexagon after exploding, but now when I connect the Mid Points as Cloud Points and Inside Points as Points, as a result, I’m missing one point in few Hexagons
GH is there for over a decade and there is no related bug known at this point. So it is almost certain that you made a mistake here. For better help, could you provide a true minimal example so that people can help you. By doing so, you might already see the problem by yourself. I guess you make a mistake with managing your data.
The problem is not with closest point, you can bake the search points and input points and see that the result is as expected. That the component does not find what you think it should find is most likely because your assumption is not correct and you need to think of another way to achieve what you want.
