I have a model on which I would like to use the hydrostatics function. Rhino is able to make a solid out of curves, but the hydrostatics function won’t work. Making an intersection shows that the curves are not closing (although the solid is) and the opening is 1.78 mm. Any advice on how to solve this?
I’m afraid that will give you nothing but trouble. Generally keep the units tolerance in the .01 > .000001 range to keep Rhino happiest.
Also, the surfaces that are selected in this image appear to be completely flat so they should be able to be modeled as very simple surfaces instead of these overly dense patches.
The selected surfaces are problematic. The red curve has a lot of points… Another problem is around the two ends. I deleted the two the two ends and capped the polysurface.
Thanks for the reply Wim. The model was actually build up with 0.01 mm tolerances but I tried to make it work with the 2 mm tolerance. Rebuilding the surface like Martin did does work.
I’ve looked at the model again. My rebuilt surfaces are actually not very nice. There are more surfaces with edges that have way too many control points. That leads to problems with sections
