How do closed entities get random colors?
closed solid polysurface.3dm (78.1 KB)
Hello- Per-face color (Ctrl-Shift click on a face ands assign color or material)
Also, RemovePerFaceColors is handy.
Thank you for your answer
one more question. how to get Per-faces colors when i deconstruct the closed solid polysurface in grasshopper?
@kike whatâs wrong here? Display color does not seem to show the correct color. The brep has perfacecolors and a copy of it is exploded for display purposeâŚ
display_color_per_face.3dm (120.7 KB)
display_color_per_face.gh (12.5 KB)
it is Rhino8ďź
Yes.
By the way, how to Bake object color to Rhino software without plugin
Martin,Thank you for your answer
Hi Martin, thatâs the problem i want to say. when you deconstruct solid brep in grasshopper, the Per-face color information will lose. hope one can help to deal with it.
However, this should work with the new Explode Object component in Rhino 8. It currently seems to have a flaw and I hope this will be fixed soon.
Iâve logged the issue - thanks for reporting.
https://mcneel.myjetbrains.com/youtrack/issue/RH-79588
â Dale
Thank you, let me learn moreďź
@martinsiegrist @evin @Ward The per-face color information should now be copied over to the exploded geometry attributes. This fix will be available in the first Rhino 8.5 release candidate.
Thank you. Waiting for 8.5 ![]()
Hi Andy, I think something is still wrong with the colors.
My test file contains one extrusion. The top face has a custom color but the rest is set to âBy Layerâ.
Layer color is white, yet the color output in the Display Colour component is 0,0,0 for five faces.
color_per_face.gh (17.3 KB)
color_per_face.3dm (67.0 KB)
Rhino 8 SR5 2024-2-16 (Rhino 8, 8.5.24047.13001, Git hash:master @ 87905d1371b0ad4e8a0bde67d968d309ed579093)
License type: Kommerziell, build 2024-02-16
License details: Cloud Zoo
Windows 11 (10.0.22631 SR0.0) or greater (Physical RAM: 128GB)
.NET 7.0.16
Computer platform: DESKTOP
Primary display and OpenGL: NVIDIA RTX A5000 (NVidia) Memory: 22GB, Driver date: 2-7-2024 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 551.52
- Secondary monitor attached to adapter port #0
- Windows Main Display attached to adapter port #1
Secondary graphics devices.
NVIDIA Quadro K2200 (NVidia) Memory: 4GB, Driver date: 2-7-2024 (M-D-Y).
- There are no monitors attached to this device!
OpenGL Settings
Safe mode: Off
Graphics level being used: OpenGL 4.6 (primary GPUâs maximum)
Anti-alias mode: 8x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 2-7-2024
Driver Version: 31.0.15.5152
Z-Buffer depth: 24 bits
Total Video Memory: 23028 MB
C:\Users\martinsiegrist\AppData\Roaming\McNeel\Rhinoceros\8.0\Plug-ins\KeyShot9RhinoPlugin (ecfe8d1f-876a-460f-aa5e-3dd816936811)\1.0.0.0\KeyShot9RhinoPlugin\Rhino 5.0\KeyShot9RhinoPlugin.rhp âKeyShot9RhinoPluginâ 1.0.0.0
C:\Users\martinsiegrist\AppData\Roaming\McNeel\Rhinoceros\packages\8.0\NVIDIADenoiser\0.4.3\NVIDIADenoiser.Windows.rhp âNVIDIADenoiser.Windowsâ 0.4.3.0
C:\Program Files\Rhino 8\Plug-ins\Commands.rhp âCommandsâ 8.5.24047.13001
C:\Program Files\Rhino 8\Plug-ins\WebBrowser.rhp âWebBrowserâ
C:\Program Files\Rhino 8\Plug-ins\rdk.rhp âRenderer Development Kitâ
C:\Program Files\Rhino 8\Plug-ins\RhinoScript.rhp âRhinoScriptâ
C:\Program Files\Rhino 8\Plug-ins\IdleProcessor.rhp âIdleProcessorâ
C:\Program Files\Rhino 8\Plug-ins\RhinoRenderCycles.rhp âRhino Renderâ 8.5.24047.13001
C:\Program Files\Rhino 8\Plug-ins\rdk_etoui.rhp âRDK_EtoUIâ 8.5.24047.13001
C:\Program Files\Rhino 8\Plug-ins\NamedSnapshots.rhp âSnapshotsâ
C:\Program Files\Rhino 8\Plug-ins\MeshCommands.rhp âMeshCommandsâ 8.5.24047.13001
C:\Program Files\Rhino 8\Plug-ins\IronPython\RhinoDLR_Python.rhp âIronPythonâ 8.5.24047.13001
C:\Program Files\Rhino 8\Plug-ins\RhinoCycles.rhp âRhinoCyclesâ 8.5.24047.13001
C:\Program Files\Rhino 8\Plug-ins\SectionTools.rhp âSectionToolsâ
C:\Program Files\Rhino 8\Plug-ins\Grasshopper\GrasshopperPlugin.rhp âGrasshopperâ 8.5.24047.13001
C:\Program Files\Rhino 8\Plug-ins\RhinoCode\RhinoCodePlugin.rhp âRhinoCodePluginâ 8.5.24047.13001
C:\Program Files\Rhino 8\Plug-ins\Toolbars\Toolbars.rhp âToolbarsâ 8.5.24047.13001
C:\Program Files\Rhino 8\Plug-ins\3dxrhino.rhp â3Dconnexion 3D Mouseâ
C:\Program Files\Rhino 8\Plug-ins\Displacement.rhp âDisplacementâ
Iâm just getting back to this (sorry). There are some good reasons why the âeffective colorâ that is output from the C-output of the Display Color component isnât exactly matching what you are expecting. The short version is that it would require a lot more overhead to solve all of the âeffectiveâ attribute values at the very beginning (ie. when the model objects are created⌠like the Query Model Objects component in this example). @kike and I have discussed adding a new component which could solve all of the object attributes and return their âeffective valuesâ. I keep using âeffectiveâ because weâre still not sure what the right terminology would be. But, for example, letâs say you have an object whose display color is listed By Layer. This new component would then go and figure out which layer that object belongs to, and return that Layerâs color so that the Display Color would then read (255,0,0⌠or whatever that layer color happens to be⌠instead of By Layer).
To get around this in the short term, your best bet is to use a Pick'n'Choose like this to match the pattern with the appropriate color. You can see in the image below that by using the PickânâChoose component, the resulting list of colors will return the color White (ie. 255,255,255) for the first five faces of your box, and then blue (ie. 29, 112, 233) for the last face. Does this help?
Thanks for the reply. At least I know I didnât do anything wrong.
