Closed Mesh to 3D print with Chitubox
I give in. I’ve spent all day on this and can’t figure out how to get this working. I’ve got a closed mesh model (attached below) and when I open it in Chitubox to slice and change to a .ctb for printing, it doesn’t treat it as a solid. Am I missing something?
Brake Light Mount.stl (1.8 MB)
Hello - the mesh has some self-intersections - use MeshSelfIntersect to see where.
and what’s the process to solve the selfintersection on meshes?
@pascal I can’t get MeshSelfIntersect to register in either Rhino 5 or 6. Where did you get this command? Thanks!
Hi -
The current version is Rhino 7. The MeshSelfIntersect is a new command in Rhino 7.
In Rhino 7, you run MeshRepair and run the repair routine in the dialog 3 times. Then flip the normals and you get what appears to be a good mesh.
