Closed Brep to closed mesh
Hei,
In some sense i recognized that closed brep doesnt mesh closed mesh.
How to solve it in this example the issue. Results should be closed mesh so Tekla Structures/other programs can read the geometry.
Closed Brep to Closed mesh.gh (169.6 KB)
private void RunScript(Mesh mesh, bool ratchet, double distance, ref object A)
  mesh.MatchEdges(distance, ratchet);
  A = mesh;
MatchEdges.gh (171.2 KB)
Hi @anon76319893 ,
Thats is a really known problem! Theoretically, a closed Brep should result in a closed mesh, however, in complex geometries, may be a decimal problem, producing an open mesh.
What I always do is:
  1. Make the transformation from brep to mesh in some coordinates close to the origin.
  2. I use the rhino/grasshopper command Align Vertices with a small tolerance i.e. 0.001
  3. I use the Rhino command Fill the holes just in case a small holes exists in the mesh
Following previous steps, meshes become as always closed.
I hope that this information proves helpful
Regards
