Hi guys
I have a problem with this curve.
I want to get a clockwise closed curve from this one
And I use the following code:
if (curvaCerrada.ClosedCurveOrientation(Plane.WorldXY) == CurveOrientation.CounterClockwise)
curvaCerrada.Reverse();
But, curvaCerrada.ClosedCurveOrientation(Plane.WorldXY) returns the curve is clockwise.
cuadradoAntiHorario.3dm (13.9 KB)
Someone can help me?
Thanks in advance
PD: All code is below
ObjRef crvRef;
Result res = RhinoGet.GetOneObject("Select closed curve", false, ObjectType.Curve, out crvRef);
if (res != Result.Success)
return res;
var curvaCerrada = crvRef.Curve();
OrientarHoraria(ref curvaCerrada);
return Result.Success;
public static void OrientarHoraria(ref Curve curvaCerrada)
if (curvaCerrada.IsClosed)
//Ponemos la orientacion como toca
else
throw new Exception("OrientarHoraria: La curva a orientar no esta cerrada");
