Clippingplane evaluates as a Surface
I just found that rhinoscriptsyntax.IsSurface() evaluates True for a clippingplane.
Is that per intention, or an oversight?
clipping_plane = rs.AddClippingPlane(rs.WorldXYPlane(),1,1)
print rs.IsSurface(clipping_plane)
>TRUE
-Willem
Hi Willem,
I’d say its an oversight, which is quite polite. Although the underlying geometry of clipping plane object is a plane surface, it shouldn’t pass the IsSurface test…
http://mcneel.myjetbrains.com/youtrack/issue/RH-33671
– Dale
It should probably pass the IsClippingPlane test, if there is such a thing. If not, maybe there should be.
(As you can tell, I haven’t written a script in quite a while.)
