I’ve looked for any solution to this and it seems like Rhino 8 has some issues with Clipping Plane or maybe I just don’t know how Rhino 8 works. I’m trying to produce basic architectural orthographic drawings. Since Rhino 6 my method has been to use a clipping plane, “cut” the section, make2d in a ortho view and then edit linework. I’m struggling with Rhino 8.
I’ve tried numerous ways to cut a section through this model. Originally I was trying to use the new feature of the Clipping Plane to ignore the building so it would cut only the step topographic model but it wasn’t working. Then I tried just cutting everything and I would manually draft the output but the output is inaccurate. You can see my Clipping Plane settings. The Right Viewport shows the intent but when creating linework using the command MAKE2D the output is something else. Is this a glitch or am I just not following the proper procedure in Rhino 8.
RhinoForums Collision Drawings 01.3dm (11.3 MB)
Rhino 8 SR25 2025-10-14 (Rhino 8, 8.25.25287.14001, Git hash:master @ 6cb5f028371cc144f33593b4e8884e14e4ebc7e9)
License type: Educational, build 2025-10-14
License details: Cloud Zoo
Windows 11 (10.0.26100 SR0.0) or greater (Physical RAM: 31GB)
.NET 8.0.14
Computer platform: DESKTOP
Primary display and OpenGL: NVIDIA GeForce RTX 5070 (NVidia) Memory: 12GB, Driver date: 10-9-2025 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 581.57
Accelerated graphics device with 4 adapter port(s)
Secondary graphics devices.
AMD Radeon™ Graphics (AMD) Memory: 1GB, Driver date: 12-24-2024 (M-D-Y).
Accelerated graphics device with 5 adapter port(s)
- There are no monitors attached to this device!
OpenGL Settings
Safe mode: Off
GPU Tessellation is: On
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 10-9-2025
Driver Version: 32.0.15.8157
Z-Buffer depth: 24 bits
Total Video Memory: 12227 MB
C:\Users\garci\AppData\Roaming\McNeel\Rhinoceros\packages\8.0\NVIDIADenoiser\0.4.3\NVIDIADenoiser.Windows.rhp “NVIDIADenoiser.Windows” 0.4.3.0
C:\Program Files\Rhino 8\Plug-ins\Commands.rhp “Commands” 8.25.25287.14001
C:\Program Files\Rhino 8\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 8.25.25287.14001
C:\Program Files\Rhino 8\Plug-ins\RhinoRender.rhp “Legacy Rhino Render”
C:\Program Files\Rhino 8\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 8.25.25287.14001
C:\Program Files\Rhino 8\Plug-ins\MeshCommands.rhp “MeshCommands” 8.25.25287.14001
C:\Program Files\Rhino 8\Plug-ins\RhinoCycles.rhp “RhinoCycles” 8.25.25287.14001
C:\Program Files\Rhino 8\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 8.25.25287.14001
Thanks for the help.
