Climate Studio Radiance trans Material
Hi there!
I am trying to do a Radiance Rendering and Point in Time Illuminance with Climate Studio.
For this I am trying to create a Radiance trans material.
(attatched file as .txt should be opened with a code editor and saved as .rad)
If I load this into Climate Studio Material Library, it is recognized as a trans material. However, when trying to make a Radiance Rendering it gives an error.
Does anybody have experience with this and can help me?
tyvek.txt (83 Bytes)
Cheers,
Miru
Hi -
Please visit https://discourse.ladybug.tools/ for questions related to the Ladybug Tools.
Hi Wim,
Thank you for the reply!
Unfortunately, this is not a Ladybug Tools problem. It is a Climate Studio ( ClimateStudio — Solemma) problem.
This Plug-in for Rhino is relatively new and doesn’t have its own forum. Or at least I couldn’t find one.
On the other hand a short UPDATE on the trans materials for Radiance:
They seem quite difficult to generate also due to the lack of documentation on actual spectrometry data of these materials. Nevertheless, I was fortunate enough to have been shown this widget that helps with trans material generation. Checking the Radiance Manual Vol 2 (1999) is useful for understanding how to set up the parameters.
Maybe this helps some of you out there.
Cherrs,
Miru
Hi Miruna,
I have similar issue than yours. I am trying to model a diffuse glazing as realistic as possible but there is not much information about it or cut sheets of this type of glazing with inputs that can be use in Radiance.
I have try to use the link for the app that you share but unfortunately is not available any more. Would it be possible for you to share it with me? did you figure out other possible methods?
Thanks
Hi @julioamodia89
For understandin Radiance and trans material generation I consulted this PDF, in which the widget was referenced.
DavidMead.pdf (8.5 MB)
And the Widget you can find here:
TransWidget.wdgt.zip (371.6 KB)
I used this to generate my trans materials back then. It seamed to work, the renderings looked quite good, but there is unfortunately no way I can say for sure that what I did was precisely accurate.
I haven’t used this in the past 2 years, so I’m not up to date with the current state of the development of trans materials in Radiance. You should definitely get in touch with someone who is using this program on a daily basis or with some developers, they have the best insight on this stuff (check out GitHub)
I hope this helps for now!
Good luck!
cheers
Miru
Thank you for the response @miruna.vecerdi I will definitely check that out.
Cheers,
Julio
Hi Miru,
May I know what code editor you used to save it as .rad file?
Thanks.
Regards,
Hari
Hi Hari,
I think I just used either a text file or Atom, and then saved the code with the extension .rad
Cheers
Hi Miru,
Thanks!!
Cheers
