Climate Studio
Hello everybody,
I am using ClimateStudio plug in for Grassoppher to perform internal shading analysis. From the website of Solemmna I learned that if you want to import a new shading system with a costum material properties you need to import a BSDF XML file into the shading Library. I modelled my shading system with optical properties on lbnl WINDOW and exported the file into ClimateStudio but it appears empy and lack of contet I set before.
Does anyone can help me? Is there another path I can follow to model internal shading system and material direclty in ClimateStudio?
Thank you in advance,
Elena
Hi Elena -
For support with the ClimateStudio plug-in, please see this post:
Hello everybody,
Does someon of you familiar with Cimate Studio plugin for RHino/Grassoppher? I need to perform daylight, thermal and energy strategy of internal shadings: I created BSDF xml file with Radiance to model my specific shading material and configuration. Right now, I am dealing with a venetian blinds and I need to insert control strategy to change the slat angle according to different paramenter, and for this scope I generated a BSDF file for each louvre angle slat.
Does someone know how to do it in Climate Studio?
Elena
