I have a question about how to change the size proportionally via BoxEdit? I saw the same question has been asked a few years ago but since than nothing changed.
Let say I have an object with 124*47 dimensions. I need to change X to 50 and Y should be recalculated automatically. Is it possible? Because when you work with a lot of different size objects and try to set X to 50 to all of them, you’ll die before you finish to recalculate Y manually.
