I have an object that has been rotated in the local x y z about the origin (i.e. rotations using the gimble with the axis system snapped to the object).
I can use a change of basis to obtain the transformation matrix from the world coordinate system to the final local system.
Is there a way to determine the x y z angular rotation in the world coordinate system?
Riccardo, thank you for your reply. Unfortunately the rotations are still around the local axes that move with the rotated object. I am looking to give three rotations on the world axes that result in the final orientation of an object.
You can obtain yaw+pitch+roll of both situation: world trasformation or local/relative trasformation; i’ve put them both ready on the example on the link.
Please find attached the sample file. I have amended your script, your script is hidden but still there for reference.
Hopefully it is clear what I am attempting and what is happening; assuming I have the start and end geometry, but don’t know the rotations made, I than want to use the angles obtained to rotate on the world axes.
However, the yaw pitch roll don’t give the correct result.
