There is a problem with your counter index (i vs j) in the second loop.
But, I think you may also be “surprised” by the so-called late evaluation of LINQ operators. When you use a Select statement, nothing is selected until you evaluate the result. In this case, you evaluate it three times by rhinoO.ElementAt(i), and each time you get a fresh object copy. I advise to change like this:
for (int i = 0; i < partitions.Count(); i++) {
Color c = Color.FromArgb(random.Next(0, 255), random.Next(0, 255), random.Next(0, 255));
IList<RhinoObject> rhinoO = partitions.ElementAt(i).Select(Rhino.RhinoDoc.ActiveDoc.Objects.Find).ToList(); // by using ToList() you force an early evaluation of the Select statement
for (int j = 0; j < rhinoO.Count(); j++) {
var obj = rhinoO[j]; // call the next three lines on the same object instance.
obj.Attributes.ObjectColor = c;
obj.Attributes.ColorSource = Rhino.DocObjects.ObjectColorSource.ColorFromObject;
obj.CommitChanges();
I was not surprised Like I said, many of the LINQ operators (like Select, Where, etc.) evaluate lazily. This is to speed up things in a complicated query. But the side effect is that you may get the operator to evaluate multiple times. And in this case, you get three times a different copy of the Rhino object.
