I’m catching up on a few change logs…
I’ve seen items come and go in the change logs before and thought I’d ask this time.
In the 2015-07-28 change log the following sweep-related items are logged:
Sweep1RH-27363 (Bug) Sweep1: Align with surface broken RH-27545 (Bug) Sweep1 dialog - change Shape to Cross section Sweep2 RH-22608 (Bug) Sweep2 w/slash & 1 shape curve - History update incorrect RH-27455 (Bug) Change Sweep2 to do simple sweeps when possible RH-27546 (Bug) Sweep2 dialog - Change Shape to Cross section
In the 2015-08-04 version only the following are logged:
Sweep1RH-27363 (Bug) Sweep1: Align with surface broken Sweep2 RH-22608 (Bug) Sweep2 w/slash & 1 shape curve - History update incorrect RH-27455 (Bug) Change Sweep2 to do simple sweeps when possible
Does this mean that RH-27545 and RH-27546 became bugs again? Both are still closed in YouTrack…
