Dear All,
I am trying in my python script to select some curves, then for every curve in the selected list I change it to a first degree curve. I have tried the rs.ChangeCurveDegree(i, 1) function, however it didn’t change anything in my case (please look at the attached pic)
Thanks in advance & Stay Safe !
Hi @kareem2292,
the method rs.ChangeCurveDegree only allows to increase a curve’s degree. Since your curves obviously have a degree larger than 1 and you try to change it to 1, nothing changes.
_
c.
Moved to Scripting category
Maybe you need something like rs.ConvertCurveToPolyline ?
Or rs.CurvePoints then rs.AddPolyline ?
hi @clement, thanks for your reply, the thing is that in normal Rhino the command change degree works easily to decrease or increase a curve’s degree, I am even trying to find it in the Rhino library but didn’t succeed !
Thanks @Jonathan_Hutchinson rs.ConvertCurveToPolyline finally worked
