Hi , could you tell me if there exist a way to decrease a trim curve’s degree in opennurbs?
think you.
Hi @dale , I want to get a lower Degree trim curve like( p = 1 or p = 2),but in rhino ,the Degree of trim curve is 3. and I want to repalce a Bezier Triangle 's edge by the lower trim curve. so is there exists any ways to decrease the trim curve’s Degree in opennurbs or in Rhino?
Thank you!
Hi @user230,
The degree of trim curves is not always 3. Trim curves are often line curves.
trimmed_plane.3dm (33.4 KB)
OpenNURBS lets you set the trim curve to anything you want.
To change a trim curve, use ON_BrepTrim::ChangeTrimCurve()
– Dale
Hi @dale , I want to modefy my trim curve’s Degree from 3 to 2;
so I need create a new curve whose Degree is 2 ,and replace it if
I use ON_brep::ChangeEdgeCurve() function,is right?
thank you.
ON_BrepEdge::ChangeEdgeCurve
does not modify the curve. It just points the edge to a different 3d curve.
– Dale
