I can’t seem to get the volume to work on a subd object
counter.3dm (194.6 KB)
Hi Kevin - Volume
works on this object, here -
Command: Volume
Calculating volume… Press Esc to cancel
Volume = 0.0114319798 (+/- 4.8e-10) cubic inches
wow, i have never got the volume to work on a subd and the file i uploaded here i still get error unable to calculate volume. if i convert it to a NURBS object I get the same volume as you got, but error on subd
Hi Kevin- it’s possible a bug was fixed in the version I have - the latest here.
Hi Pascal,
Here it works if object preselected but not if post-selected. Maybe that’s the difference between the two of you?
Edit: Rhino 7.24.22301.23001, 2022-10-28
Regards
Jeremy
Preselect Rules. Thanks, I’ll check when the Zoom meeting ends…
RH-71241 Volume: Fails on post-select
preselect here works, post select does not… that feels buggy.
ok, now I can get it to work, that helps.
Thanks
