Good evening,
I would like to know how to put a
point in the center of the rhino grid.
Let me explain :
- I create a point anywhere on the grid
- I would like to show him the center of it.
Thank you for your answers.
Good evening,
Let me explain :
The easiest way to snap to the CPlane origin is by typing 0.
Is your question about Grasshopper or Rhino? Can you give a better description of what you are trying to do?
-Kevin
Sorry, I shouldn’t have been clear enough.
I am creating a point in rhino that is not centered on the z, y, x axis
and I would like to center it with grasshopper.
thx
I’m still not clear on what you want to do.
If you want to create a centered point in Rhino, do as @martinsiegrist suggested:
Use the _Point command and when prompted for the location of the point object just enter 0.
If you want to move a point in grasshopper to the origin, this should work:
I don’t see any reason do to this though, because the result is the same as simply creating a new point at the origin.
-Kevin
If you mean zoom selected: use python.
If you mean move the point or the object use orient or move to point (Pufferfish)
move_zoom.gh (6.4 KB)
Good evening,
Understood.
Great night
