what command do you use if you have two curves and a sur
curve in center.3dm (885.3 KB)
face and you want to find the common center line between the two lines that fall on the surface? here is the example. thank you
in your case you can use ExtractIsocurve in V direction with snaps set to midpoint.
tweencurves
for each pair of segments
join
the created curves
pull
the curevs on the surface
curve in center 2re.3dm (7.3 MB)
