Can I get some hints how to make a cell background color different in an Eto GridView object? As well as the text color in a particular cell?
import Eto.Forms as forms
import Eto.Drawing as drawing
import Rhino.UI
class TestDialog(forms.Dialog):
def __init__(self):
self.Title = "Cell Colors"
self.Size = drawing.Size(450,565)
self.grid = forms.GridView()
self.grid.Size = drawing.Size(300,425)
#COLUMNS
numberColumn = forms.GridColumn()
numberColumn.HeaderText = "Row\t"
numberColumn.DataCell = forms.TextBoxCell(0)
nameColumn = forms.GridColumn()
nameColumn.HeaderText = "Name\t"
nameColumn.DataCell = forms.TextBoxCell(1)
colorColumn = forms.GridColumn()
colorColumn.HeaderText = "Color\t\t"
colorColumn.DataCell = forms.TextBoxCell(2)
self.grid.Columns.Add(numberColumn)
self.grid.Columns.Add(nameColumn)
self.grid.Columns.Add(colorColumn)
self.grid.DataStore = [['0', 'Test', 'Make me red'], ['1', 'Test', 'Green'], ['2', 'Test', 'Blue']]
layout = forms.DynamicLayout()
layout.AddRow(self.grid)
self.Content = layout
def main():
dialog = TestDialog()
dialog.ShowModal(Rhino.UI.RhinoEtoApp.MainWindow)
if __name__ == "__main__":
main()
dale
(Dale Fugier)
May 8, 2018, 10:35pm
2
Hi @Tim_Williams ,
After creating your GridView control, add a CellFormatting event like this:
self.grid.CellFormatting += self.OnCellFormatting
Then implement your formatting here:
def OnCellFormatting(self, sender, e):
e.ForegroundColor = drawing.Colors.White
if e.Row == 0:
e.BackgroundColor = drawing.Colors.Red
elif e.Row == 1:
e.BackgroundColor = drawing.Colors.Green
elif e.Row == 2:
e.BackgroundColor = drawing.Colors.Blue
I’ve modified your code (attached).
test_tim_williams.py (1.7 KB)
– Dale
tanasra
(Tanasra)
February 15, 2022, 5:48pm
4
Hey @dale , How can we go over the Rows in a for loop? there is only e.Row. there is no e.Rows. and at the same time, we cant set the e.Row = i.
I need to color rows that have 0 values in them.
thanks,
Hanan
dale
(Dale Fugier)
February 16, 2022, 1:02am
5
Hi @tanasra ,
The Grid.CellFormatting event occurs when each cell is being formatted for font and color. The event handler is passed a GridCellFormatEventArgs object, which incluides the actual cell item. From this you should be able to determine what you need.
– Dale
tanasra
(Tanasra)
February 22, 2022, 1:07pm
7
hey @dale , I wonder if we can color specific rows like that
rowsToColor = [3,4,7]
foreach (int row in rowsToColor)
if (e.Row == row )
e.BackgroundColor = Colors.LightGrey;
it is not working for me, but I need these specific rows to be colored. (rowstoColors is a list that changes each time…)
thanks,
Hanan
dale
(Dale Fugier)
February 22, 2022, 4:24pm
8
How about this?
private readonly int[] m_colorful_rows = new[] { 3, 4, 7 };
private bool IsColorfulRow(int row)
// Linq...
return m_colorful_rows.Contains(row);
private void OnGridCellFormatting(object sender, GridCellFormatEventArgs e)
if (IsColorfulRow(e.Row))
– Dale
