I am writing a Grasshopper component using Python and I want to be able to carry out a check at the beginning (when components are loaded) and cause the component to fail to load or unload it the check fails. In case it is relevant, the check actually involves a call to a dll to check whether the computer is compliant. How can I do this?
from ghpythonlib.componentbase import dotnetcompiledcomponent as component
__author__ = "piac"
# What can I put in here to carry out a check and then abort the loading (or unload)?
# Can python override the base loading method?
# Grasshopper.Kernel.GH_AssemblyPriority ???
# GH_LoadingInstruction.Abort ???
# Or is there a method that I should call that will unload?
class MyComponent(component):
def __new__(cls):
instance = Grasshopper.Kernel.GH_Component.__new__(cls,
"Axes", "Axes_1", """Draws a graphic symbol ....""",
"Display", "Preview")
return instance
# etc...
@piac - I am following your tutorial on creating a Grasshopper component, and I already have the Axes component working.
I guess it depends on how you are structuring your code but the idea would be to ensure the exception is triggered within the try block and, if so, not to execute anything which relies on the behaviour you are checking for.
In your case that might simply mean putting all of your code inside the try, (or in a function which is only called within the try block), with an error message in the except block.
Also watch out for naked exceptions:
Hi Graham, thank you for responding. Of course, I am talking about the example that Giulio provided, but I think I see what you are saying. Does what you suggest āunloadā the component, or just simply not load it?
Yes it is a generic āPythonicā pattern for doing one thing on success or another on failure; Iām afraid I cant help you with the specific issue of loading and unloading components.
