Catching Unhandled Exceptions in .NET
I’m currently working on a Rhino plugin in C# / .NET / WPF using the RhinoCommon SDK.
Is there a way to catch unhandled exceptions that occur within my plugin?
I’ve tried subscribing to the following events, without luck:
AppDomain.CurrentDomain.UnhandledException
Dispatcher.CurrentDispatcher.UnhandledException
If I throw an unhandled Exception, instead of going through my exception handler, I end up in an endless retry-loop for some odd reason. Is that by design?
Is there some built-in functionality in the RhinoCommon SDK that I’m missing that can help with this?
I’m well aware of the general try-catch syntax :slight_smile:
I’m referring to unhandled exceptions, or unexpected if you will, that you typically handle in normal WPF applications by subscribing to the aforementioned events.
Hi @grenadilla ,
Subscribing to AppDomain.CurrentDomain.UnhandledException is a way to do it. How are you handling it? Do you have a sample?
Hi @Darryl_Menezes.
Thanks for the response.
Here is how I’ve implemented the error handling:
1. Subscribe to the UnhandledException event:
public class MyPlugIn : Rhino.PlugIns.PlugIn
    protected override LoadReturnCode OnLoad(ref string errorMessage)
	    AppDomain.CurrentDomain.UnhandledException += new UnhandledExceptionEventHandler(UnhandledExceptionHandler);
	static void UnhandledExceptionHandler(object sender, UnhandledExceptionEventArgs args)
	    //Never get to here!
	    Exception e = (Exception)args.ExceptionObject;
2. Throw an unhandled exception within a command
public class MyRhinoCommand : Command
        throw new Exception("Unhandled Test");
All RunCommand functions are wrapped in a try/catch block by Rhino itself.
As @stevebaer says, Rhino is swallowing your exceptions in their own try/catch. You can however wrap your logic in each RunCommand() call, in your own try/catch if you are actually trying to handle the exception and perform necessary logic or logging.
