I would like to ask if there is any way to prevent rhino from crashing when the code has some errors?
I tried to use try catch statement but this does not help anyhow. I am not using external libraries. Each time I have to restart Rhino, therefore the development takes always a long time to debug. If there is no prevention from crash, for what try and catch statement is used in C++ ?
It depends on where your errors originated. If an exception was thrown (and you should throw exceptions that inherit from std::exception, see std::exception - cppreference.com) these can be caught. But if you, for example, dereference a null pointer, a crash will happen without an exception.
This means that you should program more defensively, checking all pointers for null, all loops for range, etc. etc. My personal experience is that about half the code I write is handling of potential errors.
Yes, I’m not a professional programmer but when I write code for somebody else, I’d say that at least 2/3 of it are to make it as fool proof as I’m able to. It’s a hard task to do, and a huge mental undertaking to think everything through and mend potential weaknesses or exploits.
The try clause well tries all code that’s placed inside of it’s scope, and when an exception occurs and you’re trying to catch that specific exception, the catch clause is run.
The more general the exception that you’re trying to catch, the better the chance, however this is considered bad programming, since it potentially obfuscates debugging information. std::exception is the mother class that all other exceptions inherit from. When you try to catch it, it potentially catches all sub exceptions. I guess you see the problem here.
However, the more specific you get, the greater the chance that you don’t catch certain ones.
I’d say don’t try to catch unknown exceptions. Only use this if you’re certain what to catch.
As Menno already pointed out, you usually want to raise the exception with the throw expression, since this also stops code execution. Outputting stuff to a console, like RhinoApp().Print(), does just that, and then continues to run.
This is what I also thought. Running python code for wrapped for C++, because C# crash as well.
I read about SEH exceptions and I added to my code.
Could you elaborated what is _set_se_translator?
Thank you @diff-arch and @menno for the advice. I know that I need to handle errors myself, but from time to time I find new ones. The bigger issue is that during development I constantly need to display geometry and rework the code. Knowing how long the Rhino application takes to load the whole debugging process becomes very slow, requiring tens of time to reload rhino.
I do not know how you guys fast debug your code. Do you first develop code outside rhino with a quick debugging like Console App or some custom visualizer and only then port to Rhino?
It would be perfect that it would be possible to automatically unload and reload .rhp files because currently .rhp cannot be rebuild unless Rhino is closed:
Severity
Code
Description
Project
File
Line
Suppression State
Error
LNK1104
cannot open file ‘C:\IBOIS57_Code\Software\Raccoon_Litter_Box\joinery_solver\x64\Release\joinery_solver_rhino7.rhp’
Briefly, it makes a separation of the commands that reside in the plug-ins, and the command implementations that reside in another assembly. This command implementation assembly is reloaded every time the command executes using Assembly.Load(File.ReadAllBytes(<path/to/implemetation-dll>)); This can be done multiple times, and the newly loaded assembly will overwrite or take precedence over the old assembly.
