Hello, I am trying to use Rhino.Runtime.PythonScript to execute Python code (that may raise exceptions) from C#. I having some difficulties catching the exceptions because the raised types are not derived from System.Exception (please see screenshots below). I was wondering how can I fix this? Thank you in advance!
Unable to catch the exception raised from IronPython.
That code does not structure a try/catch block around the ExecuteScript function, it only tries to trap the action of adding an event handler to button.Click. You would need to write a separate function with a try/catch block and have your click handler call this function.
