Hello everyone,
My first post here:)
I have encounter a problem when using ExecuteFile method in PythonScript class.
I am developing a rhino plugin in C#. And I am using another thread to listen to messages from other app and then in Rhino run some python code from local machine.
I have narrow down the buggy script as below:
Which throws an exception when debugging the code.
The exception detail is like this:
Anyone has a solution? Thanks in advance!
Also anyone who has ever used pythonscript class could you share your experience of it?
Thanks!
Rhino rocks
By the way, if I replace ExecuteFile method with ExecuteScript method, there is no such an error.
But I am willing to import other python files in my python code so ExecuteScript method does not work here.
dale
(Dale Fugier)
April 19, 2018, 11:28pm
5
Hi @jessen.ch ,
What if you don’t run the script from a thread? Rhino is not thread-safe. So this very well can be the problem.
– Dale
Hi @dale ,
Many thanks for your reply.
The reason I use thread is that I am running a TCP server to listen to messages and once received a command then run a python script.
If I run the TCP server from the main thread, the server would hang the whole Rhino application, since the TCP server runs with while (true) block.
Maybe I am doing it wrong. Is there an alternative to run the server in the background? Or how can I force the main thread to run ExecuteFile command?
Thanks to this post RunScript in a thread by @jstevenson , I have figured out how to make it!
