When using capture to bitmap in a c# script I’m getting strange results in the output file. I am exporting an image that is larger than the viewport, has anyone else encountered this before?
Thanks,
John
Hi John,
I might be wrong but I think there was an issue like this solved in a service release. You might want to try and update Rhino to the latest SR.
Do come back if the issue persist and possible add the code to replicate the problem. Its much easier for the developers to test the issue and track down the cause.
