atair
June 16, 2017, 7:56am
1
I can Serialize GeometryBase and Point3d, but not Polyline.
error: Type 'Rhino.Collections.Point3dList+XAccess' in Assembly 'RhinoCommon, Version=5.1.30000.17, Culture=neutral, PublicKeyToken=552281e97c755530' is not marked as serializable. (line: 0)
Is Polyline a special case because of the PointList parent? Or is there some pattern about what can be serialized and what not?
I assume (hope) everything derived from GeometryBase can be serialized?
dale
(Dale Fugier)
June 16, 2017, 3:27pm
2
Hi @atair ,
What serialization format are you looking for? Can you share some source code that is not working for you?
– Dale
menno
(Menno Deij - van Rijswijk)
June 16, 2017, 6:26pm
3
If you make a PolyLineCurve
it will be seralizable, because that inherits from GeometryBase
atair
June 16, 2017, 10:56pm
4
It is from a GH component - I guess that should not matter much.
Haven’t tried yet, but I can live with a PolyLineCurve as menno suggested
private void RunScript(ref object A)
data = new TestStruct(new Point3d(16, 0, 0));
byte[] serialData = ObjectToByteArray(data);
TestStruct newData = ByteArrayToObject<TestStruct>(serialData);
A = newData.a;
// <Custom additional code>
TestStruct data;
[Serializable]
public struct TestStruct {
public Point3d a;
public Polyline pline;
public TestStruct(Point3d p) {
a = p;
pline = new Polyline();
pline.Add(a);
public static byte[] ObjectToByteArray(Object obj) {
System.Runtime.Serialization.Formatters.Binary.BinaryFormatter bf = new System.Runtime.Serialization.Formatters.Binary.BinaryFormatter();
using (var ms = new MemoryStream()) {
bf.Serialize(ms, obj);
return ms.ToArray();
public static T ByteArrayToObject<T>(byte[] arrBytes) {
using (var memStream = new MemoryStream()) {
var binForm = new System.Runtime.Serialization.Formatters.Binary.BinaryFormatter();
memStream.Write(arrBytes, 0, arrBytes.Length);
memStream.Seek(0, SeekOrigin.Begin);
return (T) binForm.Deserialize(memStream);
