So I downloaded this plug in called notilus clipper and it ended up not being what I wanted and now I can’t figure out how to get this pop up from showing up every time I start rhino. I’ve tried deleting the file I downloaded, I’ve uninstalled and reinstalled rhino, and every time it opens I go to details and check “never load this plugin” and nothing has worked. The plugin is technically not installed so I cant delete it from the plugin list. Anyone know how to get this to stop popping up everytime I open rhino?
Use pluginmanager to manage or remove the plugin.
Hello- see if it is in this folder:
C:\Users\USERNAME\AppData\Roaming\McNeel\Rhinoceros\7.0\Plug-ins
If you delete its sub folder that should do it.
I deleted the folder, but it is still popping up during startup.
Hello- I would do a search on the disk for that rhp file and delete it then.
Best way to find the location it is being loaded from is through the plug-in manager:
Tools > Options > Plug-in Manager. Select the plug-in you are interested in from the list. Then click the Details open for the plug-in. In the pop-up dialog select the blue link that shows the location the plug-in resides in. Now delete the RHP file from the explorer window that opens.
Since you haven’t activated the trial, I guess the software won’t be enabled so it won’t show up on the package manager, it seems that you installed it for all users so look for the folder below:
C:\Program Files\Common Files\McNeel\Rhinoceros\7.0\Plug-ins\Notilus_Clipper (eccc432b-7947-4008-a2ac-6c7e27f58a93)
C:\Program Files\Common Files\McNeel\Rhinoceros\8.0\Plug-ins\Notilus_Clipper (eccc432b-7947-4008-a2ac-6c7e27f58a93)
Finally got it to go away! Thank you.
In rhino 8 have the same problem.
I’ve loaded regedit.exe and I’ve search and delete all with the name Notilus.
