I’m using a layout page to draw a schematic drawing of the model but I can’t get the geometry on the right layout. The geometry gets added to the first layout, although the ViewportId of the ObjectAttributes is set to the new page’s MainViewport ID. See code below.
Any suggestions?
I’m using a command using the following code:
private static int s_pageNum = 0;
private Result UpdatePageAddDelete(RhinoDoc doc)
// get the existing pages
var pageViews = doc.Views.GetPageViews();
// RhinoPageView[] existingPages = pageViews.Where(page => page.PageName.Equals(EnglishName, StringComparison.OrdinalIgnoreCase)).ToArray();
RhinoPageView[] existingPages = pageViews.Where(page => page.PageName.StartsWith(EnglishName, StringComparison.OrdinalIgnoreCase)).ToArray();
// create the new page
++s_pageNum;
Double[] pageSize = new Double[] { 210, 297 };
doc.PageUnitSystem = UnitSystem.Millimeters;
var newPage = doc.Views.AddPageView(EnglishName+String.Format("{0}", s_pageNum), pageSize[0], pageSize[1]);
if (newPage == null)
RhinoApp.WriteLine("Failed to add new page");
return Result.Failure;
RhinoApp.WriteLine("Page added. Id: {0}, Active Viewport ID: {1}.", newPage.MainViewport.Id, newPage.ActiveViewportID);
// add some geometry to the page space.
DrawRectangle(newPage, pageSize, doc);
// Note: geometry tends to be kept drawn on the first page, even if it's deleted.
// delete the existing pages.
// + foreach (var page in existingPages) page.Close(); // Close also disposes the page.
// wrap up and return.
doc.Views.Redraw();
RhinoApp.WriteLine("Done Update Page by Add and Delete.");
return Result.Success;
private void DrawRectangle(RhinoPageView pageView, Double[] size, RhinoDoc doc)
ObjectAttributes atts = new ObjectAttributes()
Name = EnglishName,
Space = ActiveSpace.PageSpace,
ViewportId = pageView.MainViewport.Id,
ColorSource = ObjectColorSource.ColorFromObject,
ObjectColor = System.Drawing.Color.Red,
Line[] l = new Line[]
new Line(new Point3d(0,0,0), new Point3d(size[0], size[1], 0) ),
new Line(new Point3d(0, size[1],0), new Point3d(size[0], 0, 0)),
var added = l.Select(line => doc.Objects.Add(new LineCurve(line), atts));
RhinoApp.WriteLine("Added lines to Page Id {0}. Line Ids: {1}", atts.ViewportId, String.Join(", ", added.Select(a => String.Format("{0}", a))));
pageView.Redraw(); //+
