Hi. I’m trying to add 2d geometry (lines, rectangle border, etc) to a layout page (not the details themselves) but, as soon as I draw it, the geometry disappears. Ie. it looks like i’m creating a rectangle, snapping to points etc, but then when I hit enter the lines disappear.
I can add text and dimensions to my page, so the layout space is receptive to additions, but I can’t draw. Is this a glitch? or am I doing something wrong?
Hello - can you please try turning off ‘GPU Tessellation’ in OPtions > View> OpenGL and see if that makes any difference?
Can you also post the results from the SystemInfo command?
Hello - thanks -you might try updating the video drivers - they’re a little old, as these things go, from the NVidia website. Also make sure the display mode you’re using in the layout has curve drawing enabled, (Display panel)
I doubt the drivers are at play here. If you can draw curves in the detail viewports or in the regular modelling viewports, then something else is going on.
