I recently updated to Version 7 SR17 and now I can’t create new aliases or edit current ones. I’m not running more than one instance. Until I updated, I’d never experienced this issue.
No idea.
Maybe reboot?
How do you mean you can’t edit them? What happens when you try?
When I create an alias or edit an existing one and then close the options window, the new alias or edited alias is not saved.
I’ve rebooted.
That’s really bizarre.
Please run the Rhino SystemInfo command so we can see the resources Rhino is seeing.
Maybe something will stick out.
Thanks
Sounds like maybe the Settings file is no being written - @thosmurray if this file exists,
“C:\Users\USERNAME\AppData\Roaming\McNeel\Rhinoceros\7.0\settings\settings-Scheme__Default.xml”
with Rhno closed, rename that file (Scheme__Default_OLD.xml or something) , start Rhino and make your changes - any different?
I tried Pascal’s suggestion, but it’s still not working.
I forgot about something…
Soon after I installed Rhino 7 I noticed that it installed into the Rhino WIP folder. Probably user error, but I never tried reinstalling it and eventually forgot about it. I wonder if that’s throwing a wrench into the works?
Rhino 7 SR17 2022-4-12 (Rhino 7, 7.17.22102.05001, Git hash:master @ 13b57035af8fb22da005ef72c56e4555d9dbcfe3)
License type: Commercial, build 2022-04-12
License details: Cloud Zoo
Windows 10.0.19043 SR0.0 or greater (Physical RAM: 32Gb)
Computer platform: DESKTOP
Primary display and OpenGL: NVIDIA GeForce GTX 1060 3GB (NVidia) Memory: 3GB, Driver date: 10-26-2021 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 472.47
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 10-26-2021
Driver Version: 30.0.14.7247
Z-Buffer depth: 24 bits
Total Video Memory: 3 GB
C:\Program Files\Rhino WIP\Plug-ins\Commands.rhp “Commands” 7.17.22102.5001
C:\Program Files\Rhino WIP\Plug-ins\WebBrowser.rhp “WebBrowser”
C:\Program Files\Rhino WIP\Plug-ins\rdk.rhp “Renderer Development Kit”
C:\Program Files\Rhino WIP\Plug-ins\RhinoScript.rhp “RhinoScript”
C:\Program Files\Rhino WIP\Plug-ins\IdleProcessor.rhp “IdleProcessor”
C:\Program Files\Rhino WIP\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 7.17.22102.5001
C:\Program Files\Rhino WIP\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 7.17.22102.5001
C:\Program Files\Rhino WIP\Plug-ins\rdk_ui.rhp “Renderer Development Kit UI”
C:\Program Files\Rhino WIP\Plug-ins\NamedSnapshots.rhp “Snapshots”
C:\Program Files\Rhino WIP\Plug-ins\Alerter.rhp “Alerter”
C:\Program Files\Rhino WIP\Plug-ins\RhinoCycles.rhp “RhinoCycles” 7.17.22102.5001
C:\Program Files\Rhino WIP\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 7.17.22102.5001
C:\Program Files\Rhino WIP\Plug-ins\3dxrhino.rhp “3Dconnexion 3D Mouse”
C:\Program Files\Rhino WIP\Plug-ins\Displacement.rhp “Displacement”
C:\Program Files\Rhino WIP\Plug-ins\Calc.rhp “Calc”
Hello - I would uninstall and reinstall, I tihnk.
OK, thanks!
