i’m new to grasshopper.
i have modeled a curve in rhino and assigned it a curve porperties.
i have desined two points as support and i cant connect both of them, only one @ a time to the Amodel box
how to resolve?
thanks,
oded
how to resolve?
thanks,
oded
either you press shift while connecting or you use the merge component of GH. It is the same as for all other GH components.
if the displacement is too large, Kiwi sets the displacement to 0. You can increase this limit with right-click on the DeformedModel-> Flying Node Limit. However, you should check your setup (loads, geometry) as deformations in this range are not physical and your structure will break in reality.
