Hi All,
I’m trying to change the line type of a NurbsCurve, but I do not succeed.
So I make test:
ON_3dPoint pt1(0.0,5.0,0.0);
ON_3dPoint pt2(10.0,15.0,0.0);
ON_Line line(pt1,pt2);
ON_3dmObjectAttributes *attributes = new ON_3dmObjectAttributes();
attributes ->SetLinetypeSource(ON::linetype_from_object);
attributes ->m_linetype_index = 3;
CRhinoObject *obj = p_doc->AddCurveObject(line, attributes );
But this failed too. The line is added to document, but the line type still remain continuos even if I change the m_linetype_index.
Does anyone have an idea how to make it works?
Thanks in advance,
Marco
dale
(Dale Fugier)
June 26, 2014, 8:06pm
2
Instead of doing this:
Do this:
CRhinoObjectAttributes attributes;
context.m_doc.GetDefaultObjectAttributes( attributes );
context.m_doc.AddCurveObject( line, &attributes );
Also, CRhinoDoc::AddCurveObject make a copy of the attributes. Thus, your code was leaking memory. The latter way won’t.
And, if you need another sample, see the following:
https://github.com/mcneel/Rhino5Samples_CPP/blob/master/SampleCommands/cmdSampleCurveLinetype.cpp
rajaa
(Rajaa Issa)
3
The linetype table starts empty. You will need to initialize it first:
CRhinoLinetypeTable& linetype_table = context.m_doc.m_linetype_table;
linetype_table.InitDefaultLinetypes();
I also think the Dashed index = 1 in the table. You can use the following to find the right index:
index = linetype_table.FindLinetype(L"Dashed");
Hi Dale and Rajaa,
I followed your suggestions and now it works fine.
Thanks a lot!
PS: rajaa the FindLinetype function returns always -1, maybe I pass the wrong name. I try to pass “Dashed” and Tratteggiata ( it means Dashed in italian) but the result it’s always the same. Maybe I’m wrong something.
Regards,
Marco
Sorry dont know C++ but maybe VB.net helps you more then enough
Works for vb.net though
Dim LineType As Integer = doc.Linetypes.Find("Dashed", False)
Maybe draw a line in rhino. Check properties > linetype. Is there a “Dashed” there?
Btw. it is Lower/higher sensitive.
Else try looping through all Doc.Linetypes and msgbox their names
For Each Line In doc.Linetypes
MsgBox(Line.Name)
Next
And see what for result you get.
