@dale,
In Rhino 7 I was successfully using this C++ code in my DLL to turn off the construction grid and axes (among other things):
// Get list of views in Rhino document.
int32_t num_views = pDoc->GetViewList(view_list, CRhinoView::ViewTypeFilter::Model);
// Removed grid/axes, switch to shaded view, zoom extents and maximize Top viewport.
for (int i = 0; i < num_views; i++) {
CRhinoView* view = view_list[i]; if (view == nullptr) continue;
CRhinoViewport& viewport = view->ActiveViewport();
viewport.SetShowConstructionGrid(false);
viewport.SetShowConstructionAxes(false);
viewport.SetShowWorldAxes(false);
viewport.SetDisplayMode(shaded_attrib->Id());
// If min/max not available use slower: RhinoDollyExtents(view)
viewport.DollyExtents(bBox, ON::world_cs);
// If Top view, maximize it. This will also make it the active view.
const ON_Viewport vp = viewport.VP(); ON_3dVector dir = vp.CameraDirection();
// Top view has parallel projection and the camera direction is down.
if (vp.IsParallelProjection() && dir.x == 0.0 && dir.y == 0.0 && dir.z < 0.0) {
if (!view->IsMaximized()) view->MaximizeRestoreView();
This has stopped working and I end up with them both still displayed:
i notice this issue was raised back in Nov. Has it been fixed and I need to use different code now?
Regards,
Terry.
