Cannot set mesh parameters in order to get only triangles faces
I’m trying to get a only triangles’ mesh from a ON_BrepFace.
I read in the documentation that the following function (from ON_MeshParameters class) could help me to reach my purpose:
  // 0 = mixed triangle and quads
  // 1 = all triangles
  // 2 = all quads
  const unsigned int FaceType() const;
  void SetFaceType(
    unsigned int face_type
Unfortunately it seems that I’m doing something wrong because after the mesh generation, if I check how many quads the mesh has I reported a number major then 0.
Then if I call the ConvertQuadsToTriangles() function i obtain what I want.
The following is my code:
ON_MeshParameters parameters = ON_MeshParameters::DefaultMesh;
parameters.SetTolerance(0.1);
parameters.SetFaceType(1);
ON_Mesh* mesh = p_bf->CreateMesh(parameters);
int quadNumber = mesh->QuadCount(); // quadNumber = 3744
if (mesh->QuadCount() > 0)
   mesh->ConvertQuadsToTriangles();
quadNumber = mesh->QuadCount(); // quadNumber = 0
Can you help me?
Many thanks.
Hi @margari,
I’ve logged the issue - https://mcneel.myjetbrains.com/youtrack/issue/RH-58029
Thanks,
– Dale
RH-58029 is fixed in the latest WIP
