Cannot recover geometry of surface stored in document
I make a surface using:
srfGeo = NurbsSurface.CreateThroughPoints(pts, nx, ny, 3, 3, False, False)
I can evaluate this surface using u & v parameters:
	for pt in zPts:
	# Find conformal z for each vertice in mesh.
	x,y,z = pt.X, pt.Y, pt.Z
	if x >= minX and x <= maxX and y >= minY and y <= maxY:
		# Initial u,v guess; scale mesh x,y by max(u,v)/max(x,y) of land.
		u, v = x*x_scale, y*y_scale
		ps = srfGeo.PointAt(u,v)
I save this surface to the document:
# Add surface to document on layer Bare Earth.
bare_earth = doc.Objects.AddSurface(srfGeo)
if not rs.IsLayer('Tree Orchard'): tree_orchard_index = setupLayer(True,'Tree Orchard')
bare_earth_index = setupLayer(True,'Bare Earth',None,'Tree Orchard',False)
setLayer([bare_earth], bare_earth_index)
I try to recover the geometry for this surface the next time I invoke my GUI:
def getGeo(id):
    obj = doc.Objects.Find(id)
    return obj.Geometry
if rs.IsLayer('Bare Earth') and rs.ObjectsByLayer('Bare Earth', False):
	objs = rs.ObjectsByLayer('Bare Earth', False)
	# Set values for bare earth related constants.
	if len(objs) == 1:
		print '1 bare earth found.'
		bare_earth = objs[0]
		print getGeo(bare_earth)
		srfGeo = getGeo(bare_earth)
		# Setup x,y scaling and surface for evaluation.
		u_range, v_range = srfGeo.Domain(0), srfGeo.Domain(1)
But the last line fails with the message:
Message: 'NoneType' object has no attribute 'Domain'
When I print srfGeo it says:
<Rhino.Geometry.Brep object at 0x0000000000000088 [Rhino.Geometry.Brep]>
I have tried to figure out what to do with the brep but so far I have not found the right technology to penetrate its cloaking shield.
How do I get this to work so I can recover the surface geometry and access points using u & v parameters?
Please help.
Regards,
Terry.
The answer to my question is:
		brep = getGeo(bare_earth)
		srfGeo = brep.Surfaces[0]
		print u_range, v_range
This gives:
0,1480.12353663758 0,2800.48147930091
and all is well.
Regards,
Terry.
