Looking for the above, thanks! … Oh, I’m starting out with a Surface object.
Hi Jim,
If you have a Rhino.Geometry.Surface
object, you can get the surface’s domain using Rhino.Geometry.Surface.Domain
. Once you have the domain, you can verify that the uv parameter falls within the bounds of the domain.
Is this what you want?
Hi Dale,
Basically what I want to do (converting something I did in VBScript,) is randomly pick coordinates on a surface and verify that those points are in the untrimmed region.
To determine whether or not a point falls on (or off) the active region of a trimmed surface, you are going to need a Rhino.Geometry.BrepFace
object, not a Rhino.Geometry.Surface object
A Rhino.Geometry.BrepFace
does reference a Rhino.Geometry.Surface object
. But it also knows about trims and loops. Note, a Rhino.Geometry.Brep
contains one or more Rhino.Geometry.BrepFace
objects.
Once you have a Rhino.Geometry.BrepFace
, then you can use Rhino.Geometry.BrepFace.IsPointOnFace
to determine if a point is on the active region.
Thanks, just had to figure out how to actually get a Brep, which I did by changing my selection stuff, but if I had a Surface object and wanted a reference to the Brep instead how would I do it? Do I use the function to “convert” the surface to a brep?
Hi Jim,
You cannot “convert” a surface to a Brep, although you can create as Brep from a surface.
But given a Brep, you can get it’s faces (BrepFace), and from a face, you can get its underlying surface.
