Recently I started using Grashopper with Rhino6.
Sometimes, Grasshopper falls to a state that you cannot select any component, you cannot drag the canvas. Right-click menu also does not show up. But all the menus are working, for example you can recompute.
Is this something that happens to only me or is there anybody experiences the same issue?
can you add video or screenshots?
Is it possible there’s an fatal error on something in the canvas that has triggered this situation?
Could you add file to check if we also have the behavior
I’ve experienced the same issue from time to time. Couldn’t connect it to any specific action I took. The only thing helping is to quit & reopen. Running the latest Rhino & GH.
Is there a white fading border around the canvas when you’re in this state?
There is nothing that I can tell GH is in this state. Just, I cannot drag the canvas, nor click anything.
I searched a little bit and came across this post.
Yes, I’m using boolean buttons with Human components, though this issue is not 100% reproducible and I need to wait until this happens next time.
This happened again today, right after I clicked a Boolean button connected to Human Bake Geometry.
I clicked again the suspect button and mouse control is recovered.
Faced the same issue while using the button to run a gh python script. Thanks for posting the solution as well. Clicking the button again fixed it and brought the functionality back to normal.
I also have this same issue. When i click boolean toggle to bake Geometry via Lunchbox and via Elefont
Hi, this is already a well-known issue. I think you can still zoom in and out. So, repeat the zoom in and out until you have the boolean toggle at the center of the campus, and click the boolean toggle again. By that, you can bring back control again.
It’s not exactly a solution, but one workaround is to click and hold the button till the bake is done, then release it. This should prevent the canvas locking up. Alternatively, use a Boolean Toogle instead.
Edit: Sorry, you’re saying this happens with a Boolean Toggle. My post was regarding Button. Need some more coffee ![]()
Thanks @AndersDeleuran I used the Boolean Toggle instead of a button and that solved the problem.
What is this white fading border? Can I turn it off? I have it very often since using Rhino 8 and have to close and reopen rhino every time make GH work again. Sometimes it seems still working, but not previewing into rhino viewport. I have no idea what to search for or what this state is so your post was the only thing I found.
Thanks!
did you find a solution? im having the same problem.
Unfortunately not.
Hi Erik and Moritz -
Please post the output from the Rhino SystemInfo command.
Is this something you can reproduce when all 3rd party plug-ins have been disabled?
I am having the same issue.
I have no Rhino 3rd party plug-ins, just in Grasshopper. However, this script doesn’t use any.
Rhino 8 SR2 2023-12-12 (Rhino 8, 8.2.23346.13002, Git hash:master @ dbefe46c12cda06610a9ab683a211aa3d16f0030)
License type: Commercial, build 2023-12-12
Apple macOS Version 12.5 (Build 21G72) (Physical RAM: 32Gb)
Mac Model Identifier: MacBookPro18,4
Language: en
.NET 7.0.0
Metal GPU Family Apple 7
Metal GPU Family Common 3
Metal GPU Family Mac 2
Graphics processors
Apple M1 Max
LG HDR WQHD (3440 x 1440 @ 60.00Hz)
Color LCD (1512 x 982 @ 120.00Hz)
USB devices
Generic: USB3.0 Card Reader
Realtek: USB 10/100/1000 LAN
Apple Inc.: Magic Keyboard with Numeric Keypad
VIA Technologies Inc. : USB 2.0 BILLBOARD
Generic: USB2.1 Hub
Bluetooth devices
None
Third party kernel extensions
None
Third party plugins
/usr/lib/swift/libswiftAppKit.dylib
/usr/lib/swift/libswiftCoreData.dylib
/usr/lib/swift/libswiftFoundation.dylib
/usr/lib/swift/libswiftCloudKit.dylib
/usr/lib/swift/libswiftContacts.dylib
/usr/lib/swift/libswiftCoreML.dylib
/usr/lib/swift/libswiftVision.dylib
/usr/lib/swift/libswiftNetwork.dylib
/usr/lib/swift/libswiftFileProvider.dylib
/usr/lib/swift/libswiftPrivate_BiomePubSub.dylib
/usr/lib/swift/libswiftPrivate_BiomeStreams.dylib
/Applications/Rhino 8.app/Contents/Frameworks/RhMaterialEditor.framework “Renderer Development Kit” 8.2.23346.1002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Commands.rhp “Commands” 8.2.23346.13002
/Applications/Rhino 8.app/Contents/PlugIns/NamedSnapshots.rhp “Snapshots” 8.2.23346.1002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RDK_EtoUI.rhp “RDK_EtoUI” 8.2.23346.13002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/MeshCommands.rhp “MeshCommands” 8.2.23346.13002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoRenderCycles.rhp “Rhino Render” 8.2.23346.13002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoCycles.rhp “RhinoCycles” 8.2.23346.13002
/Applications/Rhino 8.app/Contents/PlugIns/AnimationTools.rhp “AnimationTools” 8.2.23346.1002
/Applications/Rhino 8.app/Contents/PlugIns/SectionTools.rhp “SectionTools” 8.2.23346.1002
/Applications/Rhino 8.app/Contents/PlugIns/RhinoRender.rhp “Legacy Rhino Render” 8.2.23346.1002
/Applications/Rhino 8.app/Contents/PlugIns/Displacement.rhp “Displacement” 8.2.23346.1002
/Applications/Rhino 8.app/Contents/PlugIns/PanelingTools.rhp “PanelingTools” 8.2.23346.1002
/Applications/Rhino 8.app/Contents/PlugIns/SolidTools.rhp “SolidTools” 8.2.23346.1002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoDLR_Python.rhp “IronPython” 8.2.23346.13002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/GrasshopperPlugin.rhp “Grasshopper” 8.2.23346.13002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoCodePlugin.rhp “RhinoCodePlugin” 8.2.23346.13002
Apple macOS Version 14.2.1 (Build 23C71) (Physical RAM: 16Gb)
Mac Model Identifier: MacBookPro18,3
Language: en
.NET 7.0.0
Graphics processors
Apple M1 Pro
Color LCD (1800 x 1169 @ 120.00Hz)
USB devices
Apple Inc.: iPad
Bluetooth devices
None
None
Third party plugins
/Library/Frameworks/3DconnexionClient.framework/Versions/A/3DconnexionClient
/usr/lib/usd/libusd_ms.dylib
/usr/lib/swift/libswiftGLKit.dylib
/usr/lib/swift/libswiftGameplayKit.dylib
/usr/lib/swift/libswiftMetalKit.dylib
/usr/lib/swift/libswiftModelIO.dylib
/usr/lib/swift/libswiftSceneKit.dylib
/usr/lib/swift/libswiftSpriteKit.dylib
/usr/lib/swift/libswiftVideoToolbox.dylib
/usr/lib/swift/libswiftObservation.dylib
/usr/lib/swift/libswiftWebKit.dylib
/usr/lib/swift/libswiftNaturalLanguage.dylib
/usr/lib/swift/libswiftMapKit.dylib
/Users/moritz/.rhinocode/py39-rh8/libpython3.9.dylib
/Users/moritz/.rhinocode/py39-rh8/lib/python3.9/lib-dynload/_heapq.cpython-39-darwin.so
/Applications/Rhino 8.app/Contents/PlugIns/export_STEP.rhp “STEP Export” 8.2.23346.1002
Hi -
FWIW, Moritz continued a thread that was a year old and appeared to have had a fix at that point. I’m not at all sure that what is being reported here now is the same as what was reported in the past.
Having said that, an issue with a white border appearing on Grasshopper in Rhino 8 was reported earlier in other threads, and that issue was fixed (RH-78853) in a 8.3 release.
I notice that you both are running an 8.2 version. Does this issue go away when you change the update frequency in the Rhino options and install a current 8.3 service release candidate?
Hi Wim, that seems to have solved my issue. Thank you!
It’s fixed, yes! Thank you.
