Canceling Input points
Hi @mathieu1
Why the Input points’ polyline doesn’t disappear from viewer when I cancel Input points like it happens when I test under Rhino?
Thank you!
If you set a default value in Grasshopper, it will always be used when you empty the points. In that case, you will need to set the minimum allowed points to zero and click on “Confirm” to recompute if you want the curve to disappear.
