Is it feasible to create an export for a .3MF formatted file using Shapediver?
Bambu Lab, leading 3d printer manufacturer, uses .3MF over other formats like .STL because it can add more info, such as filament color, and other printable configuration data. Is this a format that Shapediver has worked with other companies before?
At it’s heart, .3MF is a zipped file that includes a number of files and folders, including geometry that is similar to .STL. Anyone printing on a more advanced printer won’t need to do as much configuration if they are using this file format.
In theory, it seems like the Shapediver Zip tool should handle this - but I wanted to ask directly. Also, would this type of export be supported on the Designer plan?
Thanks,
Ben
