Is there a Python method for writing to Rhino’s notes?
Thanks,
Dan
Thanks,
Dan
You can get there via scriptcontext…
import scriptcontext as sc
notes=rs.GetString("Enter your notes here")
sc.doc.Notes=notes
–Mitch
Thanks Mitch.
I’m sure you’ve already figured this out, but for the benefit of anyone else listening in, the above replaces whatever you currently have in Notes, so if anything was already in there it will be lost. So, for security’s sake - unless you really want to replace any pre-existing content - you can grab any existing notes first with the same function then replace the notes with the existing + new…
add_notes = "This is what I am adding to my notes"
curr_notes = sc.doc.Notes
sc.doc.Notes = curr_notes + add_notes
If there are no existing notes, sc.doc.Notes returns an empty string, so it works anyway.
You may want to use some more formatting, line breaks etc. - all the usual python string stuff applies.
–Mitch
Again, thanks Mitch. Very useful information.
Dan
Cool, thanks.
Could we also, using your example variables, print this out to a text string using rs.AddText as well (in addition to)?
«Randy
Sure, it’s a string like any other. And I think Mac can now finally write multiline text, so all should work fine… --Mitch
