I made changes to Rhino Render memory management that should make it more robust on mult-frame renders like through Bongo.
If you set your Rhino to update frequency Service Release Candidate you should be able to update to Rhino 7.4. This version should be much more resilient against crashes on subsequent renders
I am running Rhino 7.4. Rhino still crashes whenever I have an object with a Bongo Video Texture in the scene and try to render it. Also,(another issue) if I create a new scene showing a pointcloud being clipped by a clipping plane, it looks fine in the Rendered viewport, but when I actually try to Render the view, using Rhino Render, the clipping plane does not clip the pointcloud. If I switch to Legacy Rhino Render it works fine.
When the crash happens and the crash report dialog pops up do you send in the crash report? Preferrably with your e-mail or Discourse user name filled out so I can search for it. It’ll greatly help in figuring out why the crash happens.
