i would need an advice on how to serialize my own class. The class will contain different geometries (Mesh, Curve, Points, Brep) among other data.
One way I see is to derive my class from one type of RhinoObject (for example CRhinoCurveObject) and add all other geometries and variables as User Data. I still do not know how to do this and serialize it afterwards, but before the research I wanted to ask if this is the best way? I guess this is the starting point of the research: http://wiki.mcneel.com/developer/userdata
Since it is not necessary for the class to be a part of the Rhino document (although it might be convenient)…is it maybe easier to just derive my class from ON_Object and somehow use the Write method to save all of its members, using this example: http://wiki.mcneel.com/developer/sdksamples/archivecurve
This example seems much simpler to me…I only dont know how to “group” the geometries that belong to one class object. If my class object has a Curve, Mesh, Points and a Brep and I save them all using Write Object…later when I read them, how do I group them back together? How do I “recognize” which ones belong to which object in the MyClass array? Actually if think about it, my class doesn`t need to be derived from ON_Object(?)…only the data it contains…I just need to find a way to reconstruct the class array when data and geometries are loaded…
I’ll probably need more information to provide a good recommendation. For example, its not clear to me whether or not you want to serialize your data to 3dm files or to your own file format? Any more details about what you are doing might be helpful.
If you want to save data to 3dm files, you only have two options: 1.) Save data in the ‘document’, we call this document user data, or 2.) Save data on some object, or object user data.
And for both options, you can either write user text (simple, there are plenty of examples of this around), or you can implement complex serialization your self via deriving from ON_UserData.
Anyway, perhaps I can get some specifics from you and then provide you with more details or an example.
thanks for the quick response. I want to save my data in the .3dm file (my own file would also be an option, but it is all the same fo me and I am guessing 3dm is easier). Let us say I have an array of objects of this class:
thanks a lot. Let me just see if I understand how to implement it with my class and actually write the data into the file. As I understand CSampleSeriaIizeData represents MyClass that I am trying to save. I guess (following this example http://wiki.mcneel.com/developer/sdksamples/archivecurve) that I would first do:
for(i=0; i< array.Count(); i++)
CSampleSerializeData& data = SampleSerializePlugIn().Data();
//then I would get the geometry from my array[i] and use data.Set…() functions to copy everything from array[i] to the “data”? This copying seems redundant, but I dont see the way around it if we need this line above(which I dont quite understand)…and now? Simply:
data.Write( archive ); (or data.Read( archive); for loading)
Is this correct? When I read the file, how do I recognize different class objects? Do you think I should put in some “int counter” or “int id” as the class member to recognize when all the elements of one class are loaded and the other ones start? (I am guessing that all the elements will be written in the same order in which they are read?)
P.S. This would save an array of my objects in a separate 3dm file? Is there an easy way to save them together with the objects from the RhinoDocument? All in one file? And then recognize them when unserializing?
