'Zat a bug or desired?
bug.gh (4.6 KB)
That is probably in an exception handler in one scope up that you don’t get to see. @DavidRutten will know better if that is the case.
Hi @dsonntag,
I would call ex an undocumented keyword. The code inside of RunScript is run in a Try-Catch block and the Catch statement declares a Exception variable named ex.
Basically, choose a different variable name…
– Dale
You found an Easter Egg it seems. Good catch! ![]()
// Rolf
