C# Point array to C++
I’m trying to get an array of points from C# to C++, but it doesn’t seem that there is a publically accessible interoperable type to do so. Going off of the C# api live on github, I can seee that PullPointsToSurface uses Rhino.Collections.Point3dList.GetConstPointArray() to pass points to a native function, however GetConstPointArray() is an internal type and cannot be accessed outside of rhino common itself.
Is there any way I can do this in my own dll?
Thanks in advance.
Hi @db368,
I haven’t tested this. But this should work.
public bool TestPointCloud(IEnumerable<Point3d> points)
  if (null == points || !points.Any())
    return false;
  var pointArray = points.ToArray(); // LINQ
  var pointCount = pointArray.Length;
  return UnsafeNativeMethods.RHC_TestPointCloud(pointCount, pointArray);
public static class UnsafeNativeMethods
  [DllImport(Import.lib, CallingConvention = CallingConvention.Cdecl)]
  internal static extern Guid RHC_TestPointCloud(int pointCount, Point3d[] pointArray);
RH_C_FUNCTION bool RHC_TestPointCloud(int pointCount, /*ARRAY*/const ON_3dPoint* pointArray)
  bool rc = false;
  if (nullptr != pointArray && pointCount > 0)
    ON_PointCloud point_cloud;
    point_cloud.Append(pointCount, pointArray);
    // TODO...
    rc = true;
  return rc;
– Dale
