I am learning Rhino plugin development when wrapping C++ classes to pass data to C#.
I have question about pointers.
In C++ I have a class that has a getter of “int* values”, which is just array of integers.
I class works and I can return integer one by one from class, but do not know how to pass whole array.
But every array in C++ is a pointer. So how to return values associated with a pointer (array of integers) to C#?
I tried this when passing C++ function to C#, but ok pointers do not exist in C# and I wonder if int* is correct:
and then I print array values: int[] values = UnsafeNativeMethods.colors(5); for(int i = 0; i < values.Length; i++) Rhino.RhinoApp.WriteLine(values[i].ToString());
But try catch block gives me an exception in Rhino:
Cannot marshal ‘return value’: Invalid managed/unmanaged type combination.
Passing arrays back and fourth can be a bit of a challenge.
If you Google “PInvoke Array” you will find numerous suggestions.
The Rhino C++ SDK contains a template array class, and RhinoCommon has interop wrappers for the most popular variations of these. So if I were trying to call a Rhino C++ SDK function that returned an array of ints, I might write my C# wrapper like this:
public int[] GetIntValues()
using (var arr = new SimpleArrayInt())
var ptr_array = arr.NonConstPointer();
var count = UnsafeNativeMethods.GetIntValues(ptr_array);
if (count > 0)
return arr.ToArray();
return new int[0];
where SimpleArrayInt can be found in the Rhino.Runtime.InteropWrappers namespace.
My “C” code could then look like this:
RH_C_FUNCTION int GetIntValues(ON_SimpleArray<int>* pIntArray)
int rc = 0;
if (0 != pIntArray)
pIntArray->Append(1);
pIntArray->Append(2);
pIntArray->Append(3);
// etc...
rc = pIntArray->Count();
return rc;
Now I am trying to replicate your code within my case.
First question as I started from C++, where can I find ON_SimpleArray ?
Now I probably have to understand how to reference Rhino in C++. Any reference?
Also I have declared an array inside class and I have a getter function inside C++ class. I was thought that pointer would be deleted after I called function. Hmm
I found by search “PInvoke Array” this bit which works fine. Tested and ran it on Rhino.
Now I am wondering how to get inside a class and get an array from it.
Ech… Now I see that when I try to get pointer from a class I get random number. No errors. But no result.
program.cs (C#)
static class CPPDLL
[DllImport(“ExternalLibrary.dll”)]
private static extern IntPtr ReturnIntArray();
public static int[] ReturnIntArray(int length)
int[] ReturnArray = new int[length];
Marshal.Copy(ReturnIntArray(), ReturnArray, 0, length);
return ReturnArray;
Heh, when I tried to write something like this I get no errors but random numbers: int array[5] = myClass.GetValues();
But when I write this thing it works and I get correct values, but I have a feeling there is a better way to do this rather than copying values to new empty array instead of passing whole pointer:
Can I assume you are not a C++ programmer? Can I also assume you’ve got some kind of C++ library that you want to access from C#? Perhaps you can tell us more about what you are trying to do and why?
