C# getting input parameter if its null
I am trying to make a simple code that reads if the input line is no input, return false.
My code doesnt return the false value if the line Component input is “No parameter input found”.
How can i fix this?
Here is the simple code:
private void RunScript(Line Data, object x, object y, ref object A)
    Print(YesOrNo(Data).ToString());
  // <Custom additional code>
  public bool YesOrNo(Line input)
    if(input == null){
      return false;
    return true;
Regards,
Giorgio
Maybe the attached can shed some light?
Objects_GetTypeName_V1.gh (7.8 KB)
Rhino.Geometry.Line is a struct, so by definition can’t be null.
EDIT:
Maybe you prefer that approach:
 public bool InputHasData(IGH_Component comp, int index)
    return comp.Params.Input[index].VolatileDataCount > 0;
You used a “Type hint” on your “Data” input: Line.
Try to add a “A = Data;” in your script, you’ll find that your originally “null” object is converted to a 0-length line with start and end points to 0,0,0 … so it is never “null”.
Rhino.Geometry.Line is a non-nullable type, so from inside your c# viewpoint “Data” is always ok.
You can input your lines as GeometryBase (which is nullable, it seems…) and lately cast them as LineCurve type when you need it.
line.gh (10.2 KB)
Thanks for all the replys! Helps a lot to get what i want. Thanks again!
