The C# API has a ObjectTable.FindByUserString function. Is there an equivalent function available to the C++ API?
Hi @mike14,
No, there is no C++ equivalent. However, you can use a CRhinoObjectIterator
to iterate objects in the document and look for objects that have your user strings. For example:
int RhinoFindObjectsByUserString(
CRhinoDoc& doc,
const wchar_t* key,
const wchar_t* value,
bool bCaseSensitive,
bool bSearchGeometry,
bool bSearchAttributes,
ON_SimpleArray<const CRhinoObject*>& objects
if (nullptr == key || nullptr == value)
return 0;
ON_ClassArray<ON_wString> geokeys;
ON_ClassArray<ON_wString> attkeys;
CRhinoObjectIterator it(
CRhinoObjectIterator::normal_objects,
CRhinoObjectIterator::active_objects
it.IncludeLights(FALSE);
it.IncludeGrips(false);
it.IncludePhantoms(false);
CRhinoObject* obj = nullptr;
for (obj = it.First(); nullptr != obj; obj = it.Next())
geokeys.Destroy();
attkeys.Destroy();
const ON_Geometry* geo = (bSearchGeometry) ? obj->Geometry() : nullptr;
if (bSearchGeometry && geo)
geo->GetUserStringKeys(geokeys);
if (bSearchAttributes)
obj->Attributes().GetUserStringKeys(attkeys);
if (geokeys.Count() == 0 && attkeys.Count() == 0)
continue;
bool bAdded = false;
for (int i = 0; nullptr != geo && i < geokeys.Count(); i++)
bool bMatch = bCaseSensitive
? geokeys[i].WildCardMatch(key)
: geokeys[i].WildCardMatchNoCase(key);
if (!bMatch)
continue;
ON_wString str;
if (!geo->GetUserString(geokeys[i], str))
continue;
? str.WildCardMatch(value)
: str.WildCardMatchNoCase(value);
if (!bMatch)
continue;
objects.Append(obj);
bAdded = true;
break;
if (!bAdded)
for (int i = 0; i < attkeys.Count(); i++)
? attkeys[i].WildCardMatch(key)
: attkeys[i].WildCardMatchNoCase(key);
if (!bMatch)
continue;
ON_wString str;
if (!obj->Attributes().GetUserString(attkeys[i], str))
continue;
if (!bMatch)
continue;
bAdded = true;
break;
return objects.Count();
– Dale
OK. Thanks.
